Technical Aviation Terms
  • Thread starter Thread starter Hristos
Hristos
Karlsruhe / Germany
www.airliners.gr
Se afto to topic, tha exoume tin dinatotita na diabasoume kai na rotisoume gia diafores texnikes ekfrasis tis aeroporias; dld. ena aplo leksiko gia sxetika posts stis categories Trip-Reports kai Genika (texnika) Themata gia paradigma,
ekana mia apli arxi me merikes leksis pou theoro kapos simantika,
ean thelete na simplirosete to leksiko mas, kante to, aplos gia na min gemisi to topic me ekfrasis pou then ine toso simantika, dokimaste na grapsete tis leksis pou theorite esis simantika gia tis sisitisis tou forum,
efharisto
ACARS = Aircraft communications and reporting system
A/P = Autopilot
ALT = Altimeter
APU = Auxiliary power unit
ATA = Actual time of arrival
ATC = Air traffic control
ATCC = Air traffic control centre
CPL = Commercial pilot´s license
ETA = Estimated time of arrival
ETOPS = Extended range twin operations
FMC = Flight managment computer
F/O = First Officer
GMT = Greenwhich mean time
GPS = Global positioning unit
IATA = International Air Transport Association
ICAO = International Civil Aviation Organization
IFR = Instrument flight rules
ILS = Instrument landing system
JAR = Joint airworthiness requirements
lb = Pounds
MFD = Mulit-function display
NAV = Navigation
RTOW = Regulated take-off weight
TCAS = Traffic alert and collision avoidance system
TOW = Take off weight
V1 = Go or no-go decision speed
VR = Rotation speed
V2 = Take-off safety speed
V/S = Vertical Speed
Zulu Time = Military GMT (f.e Greece + 2h)
Πολύ καλό Hristo ..Πιστεύω ότι για να είναι λειτουργικό θα πρέπει να τα συμπληρώνεις εσύ με επεξεργασία για να είναι όλα με αλφαβητική σειρά...έτσι θα βρίσκουμε εύκολα αυτό που ζητάμε :wink:
Πολλές από τις συντομογραφίες που χρησιμοποιούμε, είναι κωδικοί (IATA και ICAO) αεροδρομίων.
Εδώ ένα site, με πολύ καλή βάση δεδομένων:
:arrow: http://www.airlinecodes.co.uk/aptcodesearch.asp :wink:
να ρωτησω και εγω κατι. μπορει καποιος να μου απαντησει (στα ελληνικα) την διαφορα IFR και VFR?
Πολύ απλά:
VFR = visual flying (rules) = πτήση εξ όψεως, κοινώς πρέπει να βλέπεις που είσαι και που πηγαίνεις, άρα καλός καιρός και ημέρα (να μη μπούμε στα special VOR).
IFR = instrument flying (rules) = πτήση με όργανα (NDB, VOR, DME, ILS), ακόμα και μέσα σε σύννεφα που δε βλέπεις πέρα από το τζάμι.
οκ σε ευχαριστω. δηλ. με το IFR γντ πχ με το GPS?
Επίσημα όχι προς το παρόν. Ο χειριστής και το αεροσκάφος πρέπει να είναι ικανοί για αεροναυτιλία και προσέγγιση με VOR, NDB, DME και προσγείωση με ILS. Στην πράξη βέβαια το GPS χρησιμοποιείται πολύ.
-- EDIT --
Στο προηγούμενο μήνυμα, όπου ανέφερα "Special VOR", διορθώστε: "Special VFR". Αλλωστε προκύπτει από τα συμφραζόμενα.
-- EDIT --
Για μεγαλύτερη ακρίβεια το VFR και το IFR μόνα τους είναι σύμβολα.
Visual Flight Rules = Κανόνες πτήσης "εξ όψεως"
Instrument Flight Rules = Κανόνες πτήσης με όργανα
Η πτήση VFR και η πτήση IFR είναι οι πτήσεις που ακολουθούν τους παραπάνω κανόνες. Οι κανόνες αυτοί έχουν να κάνουν με ύψη πτησης, συνθήκες πτήσης κλπ.
Υπαρχουν επίσης τα VMC και IMC.
VMC = Visual Meterological Conditions
IMC = Instrument Meterological Conditions
Αυτοί δεν είναι κανόνες αλλά καιρικές συνθήκες που περιλαμβάνουν τα minima για να γίνει μια πτήση VFR ή IFR. Περιλαμβάνουν βάση νεφών, απόσταση από τα νέφη και ορατότητα. Για να πραγματοποιηθεί μια VFR πτηση πρέπει να πληρούνται οι VMC και αναλόγως οι IFR πτήσεις πρέπει να γίνονται οταν πληρούνται οι IMC.
Ελπίζω να μην σε μπέρδεψα παραπάνω απλά τα είπα πιο αναλυτικά για κάποιον που θέλει παραπάνω λεπτομέριες.
